: 1 10 23
     avatar   xlife
    Feb 2009
    117
    ssh (putty)
    May 2006
    278
    xlife
    ssh (putty)
    Connection timed out ssh.
    pin bullet. putty "TFTPD: waiting for connection...". .
    , led ( 1,3 2,4) putty ( ) "ae531x_poll: Bad receive. rxDesc=0x80038180 cmdsts=0x00408722"
    Ethernet eth0: MAC address 00:27:22:09:ac:9a
    IP: 0.0.0.0/255.255.255.0, Gateway: 0.0.0.0
    Default server: 0.0.0.0
    RedBoot(tm) bootstrap and debug environment [ROMRAM]
    Ubiquiti Networks certified release, version 0.9.8.06 - built 10:58:08, Dec 23 2008
    Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
    Board: Ubiquiti AR2315/6/7/8 based board
    RAM: 0x80000000-0x81000000, [0x00000000-0x00000000] available
    FLASH: 0xbfc00000 - 0xbfff0000, 64 blocks of 0x00010000 bytes each.
    RESET button pressed, starting rescue mode...
    TFTPD initialized on 192.168.1.20/255.255.255.0 port: 69 (Memory: [0x80040c00-0x80fe1000])
    ae531x_poll: Bad receive. rxDesc=0x80038194 cmdsts=0x00408722
    ae531x_poll: Bad receive. rxDesc=0x800381a8 cmdsts=0x00408722
    ae531x_poll: Bad receive. rxDesc=0x800381bc cmdsts=0x00408722
    ae531x_poll: Bad receive. rxDesc=0x800381d0 cmdsts=0x00408722
    ae531x_poll: Bad receive. rxDesc=0x800381e4 cmdsts=0x00408722
    ae531x_poll: Bad receive. rxDesc=0x800381f8 cmdsts=0x00408722
    ae531x_poll: Bad receive. rxDesc=0x8003820c cmdsts=0x00728722
    , , led
    PCMan : 19-07-15 15:09
    May 2006
    278
    boot recovery mode,
    Ubiquiti Networks certified release, version 0.9.8.06 - built 10:58:08, Dec 23 2 008
    RAM: 0x80000000-0x81000000, [0x80040880-0x80fe1000] available
    == Executing boot script in 1.000 seconds - enter ^C to abort
    RedBoot> cache off
    RedBoot> fis load -d -e kernel
    Trying LZMA decompression...
    Image loaded from 0x80041000-0x80286086
    Image is not ELF, skipping ELF parsing...
    RedBoot> go
    Linux version 2.6.26.8 (agb@arrakis) (gcc version 4.1.2) #4 Tue Dec 29 14:55:54 UTC 2009
    CPU revision is: 00019064 (MIPS 4KEc)
    Determined physical RAM map:
    memory: 01000000 @ 00000000 (usable)
    Initrd not found or empty - disabling initrd
    Zone PFN ranges:
    Normal 0 -> 4096
    Movable zone start PFN for each node
    early_node_map[1] active PFN ranges
    0: 0 -> 4096
    Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
    Kernel command line: console=ttyS0,9600 rootfstype=squashfs,jffs2 init=/etc/prei nit
    Primary instruction cache 16kB, VIPT, 4-way, linesize 16 bytes.
    Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 16 bytes
    PID hash table entries: 64 (order: 6, 256 bytes)
    console [ttyS0] enabled
    Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Memory: 13548k/16384k available (1898k kernel code, 2836k reserved, 304k data, 1 24k init, 0k highmem)
    SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    Mount-cache hash table entries: 512
    net_namespace: 644 bytes
    NET: Registered protocol family 16
    Radio config found at offset 0xf8(0x1f
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 512 (order: 0, 4096 bytes)
    TCP bind hash table entries: 512 (order: -1, 2048 bytes)
    TCP: Hash tables configured (established 512 bind 512)
    TCP reno registered
    ar531x: Registering GPIODEV device
    squashfs: version 3.0 (2006/03/15) Phillip Lougher
    Registering mini_fo version $Id$
    JFFS2 version 2.2. (NAND) (SUMMARY) 2001-2006 Red Hat, Inc.
    msgmni has been set to 26
    io scheduler noop registered
    io scheduler deadline registered (default)
    gpiodev: gpio device registered with major 254
    gpiodev: gpio platform device registered with access mask FFFFFFFF
    Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
    serial8250: ttyS0 at MMIO 0xb1100003 (irq = 37) is a 16550A
    eth0: Atheros AR231x: 00:27:22:09:ac:9a, irq 4
    ar2313_eth_mii: probed
    eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01)
    cmdlinepart partition parsing not available
    Searching for RedBoot partition table in spiflash at offset 0x3d0000
    Searching for RedBoot partition table in spiflash at offset 0x3e0000
    7 RedBoot partitions found on MTD device spiflash
    Creating 7 MTD partitions on "spiflash":
    0x00000000-0x00030000 : "RedBoot"
    0x00030000-0x000f0000 : "kernel"
    0x000f0000-0x003c0000 : "rootfs"
    mtd: partition "rootfs" set to be root filesystem
    mtd: partition "rootfs_data" created automatically, ofs=270000, len=150000
    0x00270000-0x003c0000 : "rootfs_data"
    0x003c0000-0x003e0000 : "cfg"
    0x003e0000-0x003ef000 : "FIS directory"
    0x003ef000-0x003f0000 : "RedBoot config"
    0x003f0000-0x00400000 : "boardconfig"
    TCP vegas registered
    NET: Registered protocol family 17
    802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    All bugs added by David S. Miller <davem@redhat.com>
    VFS: Mounted root (squashfs filesystem) readonly.
    Freeing unused kernel memory: 124k freed
    Please be patient, while OpenWrt loads ...
    Algorithmics/MIPS FPU Emulator v1.5
    - preinit -
    Press CTRL-C for failsafe
    switching to jffs2
    mini_fo: using base directory: /
    mini_fo: using storage directory: /jffs
    - init -
    Please press Enter to activate this console. device eth0 entered promiscuous mode
    br-lan: port 1(eth0) entering learning state
    br-lan: topology change detected, propagating
    br-lan: port 1(eth0) entering forwarding state
    PPP generic driver version 2.4.2
    ip_tables: (C) 2000-2006 Netfilter Core Team
    nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
    ath_hal: module license 'Proprietary' taints kernel.
    ath_hal: 2009-05-08 (AR5212, AR5312, RF5111, RF5112, RF2316, RF2317, REGOPS_FUNC, TX_DESC_SWAP, XR)
    ath_ahb: trunk
    wlan: trunk
    wlan: mac acl policy registered
    ath_rate_minstrel: Minstrel automatic rate control algorithm 1.2 (trunk)
    ath_rate_minstrel: look around rate set to 10%
    ath_rate_minstrel: EWMA rolloff level set to 75%
    ath_rate_minstrel: max segment size in the mrr set to 6000 us
    Atheros HAL provided by OpenWrt, DD-WRT and MakSat Technologies
    wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
    wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
    wifi0: turboG rates: 6Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
    wifi0: H/W encryption support: WEP AES AES_CCM TKIP
    ath_ahb: wifi0: Atheros 2317 WiSoC REV1: mem=0xb0000000, irq=3
    E▒▒▒▒▒▒▒▒▒▒=▒ð▒[▒~LnNo▒ʊ▒▒▒▒▒▒▒X▒(
    Fwwy▒ v3>13.6 (600;?q06 11:67:4? UTC) b}k▒|-{▒ sxe▒▒▒▒▒>?▒▒~▒▒▒▒2▒▒▒2 ▒▒▒|??▒▒▒~W▒▒▒▒▒ ▒▒▒kۋ{▒=95+▒׸▒<▒▒▒▒▒▒º ¸▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒
    ▒▒▒▒▒▒▒▒▒▒▒▒r▒▒▒▒ ▒▒▒▒▒▒▒␐▒▒▒▒▒▒▒▒ ▒▒▒▒▒ ▒▒▒
    ▒uI[▒▒▒`xx~p{.2< ▒q8y6q9 ▒▒9▒=▒=▒▒▒▒▒▒▒=▒▒▒=i ▒ɀ▒▒▒▒`Vo▒k▒ ` `▒h▒▒m ▒▒▒l▒<▒`▒▒▒`a▒▒▒▒z▒▒ ▒▒▒▒▒▒Y▒6r+▒▒▒ٕ▒▒▒▒ ▒▒▒h▒0▒{{Ͽc▒▒▒▒▒�▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒5)▒▒▒ ▒▒▒5 ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ (xh▒▒5i▒▒5)▒▒▒ձ▒ se▒ver: 0.▒▒▒▒▒ǜ▒,_▒▒▒▒▒▒▒▒ ▒>▒▒>?v▒▒͕ɽ▒▒=▒▒]▒▒▒'A▒ù▒3▒8▒8▒▒▒8▒▒ֺ▒ ▒▒>▒▒▒▒▒▒▒2▒2▒2▒j:▒ ▒▒▒▒ϡ▒/A▒遹▒с▒▒ߙ▒▒▒▒>r▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒VV▒ ▒▒▒ז▒▒▒r▒r▒j▒▒▒އol▒▒? ▒▒▒▒▒▒0▒?▒:or@
    Y▒'▒▒i}+ɽ▒▒▒/▒:yJml▒▒h>▒JX▒▒▒Ʌ▒▒▒▒▒▒ ▒▒՝▒▒▒٥ɽ▒▒▒▒сmI=5I5u5)▒▒ ▒▒▒▒͡▒▒▒хၕ▒ɽ▒▒ݽɑ▒չ ▒▒▒ѕ▒▒▒▒▒▒▒ѥ▒▒▒▒▒ ▒▒5)ɽ▒▒=▒▒]▒▒齍▒U▒▒▒եѥ▒9▒▒ݽ*́▒▒ ѥ▒▒▒▒▒ɕ▒▒▒͕▒▒ٕ▒ͥ▒▒ ▒▒▒▒▒ف▒▒▒ե▒с▒▒55)▒▒ ▒▒᱁▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒▒▒>2:▒ ▒ߣ▒ډ▒▒▒*▒Ӂ▒▒▒▒▒=▒ߋ? ▒▒▒▒▒jv▒▒▒?▒▒▒▒▒▒i ▒▒▒▒▒!`3I▒▒▒▒▒▒▒▒b▒ ▒▒b▒▒▒▒▒▒▒▒!▒ѱ▒%▒▒ 5)▒▒▒▒▒▒͡▒▒▒хၕ▒ɽ▒▒ݽ ɑ▒չ▒▒▒▒ѕ▒▒▒▒▒▒▒ѥ▒▒ ▒▒▒▒▒5)ɽ▒▒=▒▒]▒▒齍▒5)ɽ▒▒=▒▒]▒▒齍▒ ▒▒ɑ▒U▒▒▒եѥ▒I▒▒▒սٽݽ၉▒ ͕▒▒▒▒▒ɑ5)▒▒▒▒▒▒͡▒ ▒▒ɑ▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I5▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒m▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒u▒▒م▒ ▒▒▒▒▒5)▒▒▒▒▒▒͡▒I5▒遹 с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒1M!▒▒቙▒▒▒▒▒▒▒▒ ቙▒▒▒▒▒▒▒▒с▒▒▒▒▒́▒ ▒▒▒▒▒▒▒▒▒▒▒▒▒▒ѕ́▒ 55)▒▒▒5)▒▒▒▒▒▒͡▒1M!▒遹 с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒ѽ▒▒▒▒▒▒5)▒▒▒▒▒ ͡▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I▒▒ ▒▒▒▒▒▒▒▒▒▒5)▒▒▒▒▒▒ ͡▒I▒▒ ▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I▒▒ ▒▒▒▒́▒▒▒▒▒▒▒▒▒▒▒▒ ▒ɹ▒▒5)▒▒▒▒▒▒͡▒I▒▒ ▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒Q▒她▒▒1i5▒▒▒▒▒▒▒ ▒ͥ▒▒▒▒▒5)▒▒▒▒▒▒͡▒Q▒ 她▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒%▒▒▒▒▒▒▒▒▒▒▒▒ ɽ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒5)▒▒▒▒▒▒͡▒%▒ ▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒%▒▒▒▒▒▒́▒▒с1▒▒* ▒▒▒▒▒▒1▒▒▒ͥ▒▒▒▒▒5)▒ ▒▒▒▒▒͡▒%▒▒▒▒遹▒с▒▒չ 5)ɽ▒▒=▒▒]▒▒齍▒I▒▒ ▒▒▒▒5)▒▒▒▒▒▒͡▒I▒▒ ▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒1▒▒▒▒ٕ▒ͥ▒▒AU▒ɗۧ̓ ▒▒▒▒▒ކ▒▒▒▒▒▒~$Ӯ~o▒X▒ ▒▒▒As▒n▒▒x ▒▒[: "(" ▒▒ex▒▒▒▒,▒▒▒/▒▒▒▒3▒▒O▒▒yE▒á^▒▒▒,
    I▒▒▒▒▒H▒[;▒▒{落 ▒▒_;߯▒▒▒▒▒'▒▒▒X▒=▒gnW▒: o40v▒▒▒_▒:▒▒LL▒\▒▒H▒X▒▒H X▒▒▒▒▒~▒>y▒G▒篆▒▒? s{▒tax er▒o▒▒ "(b`w▒▒xp▒ct▒▒
    ▒▒▒▒po▒▒▒▒# ▒▒▒▒▒▒`▒▒▒`n﹑@▒▒`empty - ▒i▒▒b▒▒n)˥▒▒▒2▒▒▒▒▒V▒ ▒▒▒▒▒▒t ▒▒w{ۜ▒▒=Õ▒]▒▒뿟▒i▒▒▒▒C㧐▒a6▒{▒?s▒▒ ▒▒▒▒▒��▒3▒Ӄ2▒߻▒=ɽ▒▒}▒ ▒]▒▒齍▒▒▒y▒▒mal 0 => <09>?fy▒/▒▒▒> ▒orma|: ~ot ▒▒▒▒▒
    ▒|@Op▒▒▒?▒▒▒▒▒||▒▒▒|?▒ ▒▒▒O▒߅▒▒▒ݽ▒▒55/▒Z▒+▒▒?▒▒▒▒▒��ݻ▒?9ɿ▒▒} ▒}▒▒▒>
    ▒▒۱▒▒▒▒▒▒m▒u▒▒▒ѥۗ▒A ▒|^▒▒▒▒蜐▒8▒▒g▒▒o▒ ▒▒▒▒r▒o▒@
    ▒▒▒▒▒▒▒▒▒▒▒▒逃▒▒▒ ▒▒▒▒▒��▒▒▒▒▒}(▒▒▒▒){ 遂▒ҁr▒▒ f▒ߋ▒HH▒▒
    ▒▒▒{Y▒▒{▒X\▒▒{{z~▒▒
    Y▒ne K▒▒▒, mobZ[▒▒▒H▒ׯ▒o▒▒o|▒▒▒'▒z?c`[▒▒▒o▒`c▒▒▒▒~▒`▒i~m: co▒sol▒=t|▒▒p,y~0p root糴▒▒▒W_▒▒▒|▒▒_▒▒d▒▒ _▒▒▒▒▒ɗ▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒/▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒L▒▒▒չ]▒▒齍A▒r▒{K烓▒я▒▒▒▒▒▒▒ ▒o~ gcgx▒`qv▒▒| vIPT< 4?▒cy, lyng▒y~e 36 ▒▒|m▒.
    ▒▒▒▒▒峀ReCq▒▒▒▒▒▒▒▒▒ ͱ▒��ͥ靁▒▒▒▒y▒C#▒▒=)▒▒▒ /x▒▒▒▒x▒>▒▒ ▒▒▒▒l▒▒▒▒▒x▒▒▒▒I▒▒as ▒▒▒<,▒▒▒▒t▒▒▒▒Ѐ▒▒ˑ▒ 0:▒7▒▒2��▒ ▒▒▒)?▒▒▒▒ntX~HK▒[끉▒▒▒▒▒▒▒▒<m▒▒X▒▒▒▒ ▒{y▒▒▒o▒f {▒▒yHY?K▒▒▒▒X▒I;▒▒)k▒~ ▒▒▒▒▒▒▒▒▒▒3▒▒▒ 忿▒▒"entry`ca▒he h▒sh ta▒▒o o▒▒▒▒▒▒z`2p|x`8▒▒▒f▒▒▒Ɂy| es)
    /by▒?ash:`▒▒n▒ax`er▒o▒▒▒▒▒▒ mgt▒▒G▒▒▒O▒▒▒▒▒g InﲲK▒▒w▒ߣ▒х▒��▒▒▒▒▒▒▒ ▒▒▒۳▒▒▒▒▒҂▒▒ͥ)▒▒in/ash: syntax error: "(" unexpected
    root@OpenWrt:/# Memory: 13548k/16384k available (1898k kernel code, 2836k reserv
    /bin/ash: syntax error: "(" unexpected
    root@OpenWrt:/# SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, N
    odes=1
    /bin/ash: SLUB:: not found
    root@OpenWrt:/# Mount-cache hash table entries: 512
    /bin/ash: Mount-cache: not found
    root@OpenWrt:/# net_namespace: 644 bytes
    /bin/ash: net_namespace:: not found
    root@OpenWrt:/# NET: Registered protocol family 16
    /bin/ash: NET:: not found
    root@OpenWrt:/# Radio config found at offset 0xf8(0x1f
    root@OpenWrt:/# NET: Registered protocol family 2
    root@OpenWrt:/# IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    root@OpenWrt:/# TCP established hash table entries: 512 (order: 0, 4096 bytes)
    root@OpenWrt:/# TCP bind hash table entries: 512 (order: -1, 2048 bytes)
    root@OpenWrt:/# TCP: Hash tables configured (established 512 bind 512)
    root@OpenWrt:/# TCP reno registered
    /bin/ash: TCP: not found
    root@OpenWrt:/# ar531x: Registering GPIODEV device
    /bin/ash: ar531x:: not found
    root@OpenWrt:/# squashfs: version 3.0 (2006/03/15) Phillip Lougher
    root@OpenWrt:/# Registering mini_fo version $Id$
    /bin/ash: Registering: not found
    root@OpenWrt:/# JFFS2 version 2.2. (NAND) (SUMMARY) 2001-2006 Red Hat, Inc.
    root@OpenWrt:/# msgmni has been set to 26
    /bin/ash: msgmni: not found
    root@OpenWrt:/# io scheduler noop registered
    /bin/ash: io: not found
    root@OpenWrt:/# io scheduler deadline registered (default)
    root@OpenWrt:/# gpiodev: gpio device registered with major 254
    /bin/ash: gpiodev:: not found
    root@OpenWrt:/# gpiodev: gpio platform device registered with access mask FFFFFF
    FF
    root@OpenWrt:/# Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing
    disabled
    /bin/ash: Serial:: not found
    root@OpenWrt:/# serial8250: ttyS0 at MMIO 0xb1100003 (irq = 37) is a 16550A
    root@OpenWrt:/# eth
    May 2006
    278
    boot recovery mode,
    RedBoot> cache off
    RedBoot> go
    Zone PFN ranges:
    Normal 0 -> 4096
    0: 0 -> 4096
    TCP reno registered
    - preinit -
    switching to jffs2
    - init -
    ath_ahb: trunk
    wlan: trunk
    E▒▒▒▒▒▒▒▒▒▒=▒&#240;▒[▒~LnNo▒ʊ▒▒▒▒▒▒▒X▒(
    Fwwy▒ v3>13.6 (600;?q06 11:67:4? UTC) b}k▒|-{▒ sxe▒▒▒▒▒>?▒▒~▒▒▒▒2▒▒▒2▒▒▒|??▒▒▒~W▒▒▒▒▒ ▒▒▒kۋ{▒=95+▒׸▒<▒▒▒▒▒▒&#186;&#184;▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒
    ▒▒▒▒▒▒▒▒▒▒▒▒r▒▒▒▒▒▒▒▒▒▒▒▒␐▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒
    ▒uI[▒▒▒`xx~p{.2< ▒q8y6q9 ▒▒9▒=▒=▒▒▒▒▒▒▒=▒▒▒=i▒▒ɀ▒▒▒▒`Vo▒k▒ ` `▒h▒▒m ▒▒▒l▒<▒`▒▒▒`a▒▒▒▒z▒▒▒▒▒▒▒▒▒Y▒6r+▒▒▒ٕ▒▒▒▒▒▒▒▒h▒0▒{{ Ͽc▒▒▒▒▒�▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5)▒▒▒▒▒▒▒5 ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒(xh▒▒5i▒▒5)▒▒▒ձ▒ se▒ver: 0.▒▒▒▒▒ǜ▒,_▒▒▒▒▒▒▒▒▒▒>▒▒>?v▒▒͕ɽ▒▒=▒▒]▒▒▒'A▒&#249;▒3▒8▒8▒▒▒8▒▒ֺ▒▒▒▒>▒▒▒▒▒▒▒2▒2▒2▒j:▒▒▒▒ ▒▒ϡ▒/A▒遹▒с▒▒ߙ▒▒▒▒>r▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒VV▒ ▒▒▒ז▒▒▒r▒r▒j▒▒▒އol▒▒?▒▒▒▒▒▒▒0▒?▒:or@
    Y▒'▒▒i}+ɽ▒▒▒/▒:yJml▒▒h>▒JX▒▒▒Ʌ▒▒▒▒▒▒▒▒՝▒▒▒٥ɽ▒▒▒▒сmI=5I5u5)▒▒▒▒▒ ▒͡▒▒▒хၕ▒ɽ▒▒ݽɑ▒չ▒▒▒▒ѕ▒▒▒▒▒▒▒ѥ▒▒▒▒▒▒▒5)ɽ▒▒=▒▒]▒▒齍▒U▒▒▒եѥ▒9▒▒ݽɭ́▒▒▒ѥ▒▒▒▒▒ɕ▒▒▒͕▒▒ٕ▒ͥ▒▒▒▒▒▒▒ف▒▒▒ե▒с ▒▒55)▒▒▒▒▒᱁▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>2:▒▒▒ߣ▒ډ▒▒ ▒ӭ▒Ӂ▒▒▒▒▒=▒ߋ?▒▒▒▒▒▒jv▒▒▒?▒▒▒▒▒▒i▒▒▒▒▒▒!`3I▒▒▒▒▒▒▒▒ b▒▒▒▒b▒▒▒▒▒▒▒▒!▒ѱ▒%▒▒▒5)▒▒▒▒▒▒͡▒▒▒хၕ▒ɽ▒▒ݽɑ▒չ▒▒▒▒ѕ▒ ▒▒▒▒▒▒ѥ▒▒▒▒▒▒▒5)ɽ▒▒=▒▒]▒▒齍▒5)ɽ▒▒=▒▒]▒▒齍▒ ▒▒ɑ▒U▒▒▒եѥ▒I▒▒▒սٽݽ၉▒͕▒▒▒▒▒ɑ5)▒▒▒▒▒▒͡▒ ▒▒ɑ▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I5▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒m▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒ ▒م▒▒▒▒▒▒5)▒▒▒▒▒▒͡▒I5▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒1M!▒▒቙▒▒▒▒▒▒▒▒▒቙▒▒▒▒▒▒▒▒с▒▒▒▒▒́▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ѕ́▒▒55)▒▒▒5)▒▒▒▒▒▒͡▒1M!▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒ѽ▒▒▒▒▒▒5)▒▒▒▒▒▒͡▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I▒▒ ▒▒▒▒▒▒▒▒▒▒5)▒▒▒▒▒▒͡▒I▒▒ ▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I▒▒ ▒▒▒▒́▒▒▒▒▒▒▒▒▒▒▒▒▒ɹ▒▒5)▒▒▒▒▒▒͡▒I▒▒ ▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒Q▒她▒▒1i5▒▒▒▒▒▒▒ɕ▒ͥ▒▒▒▒▒5)▒▒▒▒▒▒͡▒Q▒她▒遹▒с▒▒չ▒5) ɽ▒▒=▒▒]▒▒齍▒%▒▒▒▒▒▒▒▒▒▒▒▒▒ɽ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒5)▒▒▒▒▒▒͡ ▒%▒▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒%▒▒▒▒▒▒́▒▒с1▒▒ͭ▒▒▒▒▒▒1▒▒▒ͥ▒▒▒▒▒5)▒▒▒▒▒▒͡▒%▒▒▒▒ 遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒I▒▒ ▒▒▒▒5)▒▒▒▒▒▒͡▒I▒▒ ▒▒▒遹▒с▒▒չ▒5)ɽ▒▒=▒▒]▒▒齍▒1▒▒▒▒ٕ▒ͥ▒▒AU▒ɗۧ̓ϐ▒▒▒▒▒ކ▒▒▒▒▒▒~$Ӯ~o▒X▒▒▒▒▒As▒n▒ ▒x ▒▒[: "(" ▒▒ex▒▒▒▒,▒▒▒/▒▒▒▒3▒▒O▒▒yE▒&#225;^▒▒▒,
    I▒▒▒▒▒H▒[;▒▒{落 ▒▒_;߯▒▒▒▒▒'▒▒▒X▒=▒gnW▒:o40v▒▒▒_▒:▒▒LL▒\▒▒H▒X▒▒H▒X▒ ▒▒▒▒~▒>y▒G▒篆▒▒? s{▒tax er▒o▒▒ "(b`w▒▒xp▒ct▒▒
    ▒▒▒▒po▒▒▒▒# ▒▒▒▒▒▒`▒▒▒`n﹑@▒▒`empty - ▒i▒▒b▒▒n)˥▒▒▒2▒▒▒▒▒V▒▒▒▒▒▒▒t ▒▒w{ۜ▒▒=&#213;▒]▒▒뿟▒i▒▒▒▒C㧐▒a6▒{▒?s▒▒▒▒▒▒▒▒󿻿▒3▒Ӄ2▒߻▒=ɽ▒▒}▒▒]▒▒齍▒▒▒y▒▒mal 0 => <09>?fy▒/▒▒▒> ▒orma|: ~ot ▒▒▒▒▒
    ▒|@Op▒▒▒?▒▒▒▒▒||▒▒▒|?▒▒▒▒▒O▒߅▒▒▒ݽ▒▒55/▒Z▒+▒▒?▒▒▒▒▒󁸿ݻ▒?9ɿ▒▒}▒▒}▒▒▒>
    ▒▒۱▒▒▒▒▒▒m▒u▒▒▒ѥۗ▒A▒▒|^▒▒▒▒蜐▒8▒▒g▒▒o▒ ▒▒▒▒r▒o▒@
    ▒▒▒▒▒▒▒▒▒▒▒▒逃▒▒▒▒▒▒▒▒▒򃁀▒▒▒▒▒}(▒▒▒▒){▒遂▒ҁr▒▒ f▒ߋ▒HH▒▒
    ▒▒▒{Y▒▒{▒X\▒▒{{z~▒▒
    Y▒ne K▒▒▒, mobZ[▒▒▒H▒ׯ▒o▒▒o|▒▒▒'▒z?c`[▒▒▒o▒`c▒▒▒▒~▒`▒i~m: co▒sol▒=t|▒▒p,y~0p root糴▒▒▒W_▒▒▒|▒▒_▒▒d▒▒▒_▒▒▒▒▒ɗ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒/▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒L▒▒▒չ]▒▒齍A▒r▒{K烓▒я▒▒▒▒▒▒▒▒▒o~ gcgx▒`qv▒▒| vIPT< 4?▒cy, lyng▒y~e 36 ▒▒|m▒.
    ▒▒▒▒▒峀ReCq▒▒▒▒▒▒▒▒▒ߵͱ▒𥹟ͥ靁▒▒▒▒y▒C#▒▒=)▒▒▒▒/x▒▒▒▒x▒>▒▒ ▒▒▒▒l▒▒▒▒▒x▒▒▒▒I▒▒as▒▒▒<,▒▒▒▒t▒▒▒▒Ѐ▒▒ˑ▒▒0:▒7▒ ▒2󮯀▒ ▒▒▒)?▒▒▒▒ntX~HK▒[끉▒▒▒▒▒▒▒▒<m▒▒X▒▒▒▒▒▒{y▒▒▒o▒f {▒▒yHY?K▒▒▒▒X▒I;▒▒)k▒~ ▒▒▒▒▒▒▒▒▒▒3▒▒▒ 忿▒▒"entry`ca▒he h▒sh ta▒▒o o▒▒▒▒▒▒z`2p|x`8▒▒▒f▒▒▒Ɂy|es)
    /by▒?ash:`▒▒n▒ax`er▒o▒▒▒▒▒▒▒mgt▒▒G▒▒▒O▒▒▒▒▒g InﲲK▒▒w▒ߣ▒х▒󗁵▒▒▒▒▒▒▒▒▒▒۳▒▒▒▒▒҂▒▒ͥ)▒▒in/ash: syntax error: "(" unexpected
    odes=1
    FF
    disabled
    root@OpenWrt:/# eth
    May 2006
    278
    May 2006
    278
    ssh tftp .
    recovery mode ( recovery mode), led . ,
