Επίσης κοίτα και αυτό εδώ:
I had the same problem trying to enable wimboot ran into problmes and needed the usb stick. Luckily I made it before but also used it to modify the .wim images and it wasn't bootable anymore.
So what you should do:
1. create a usb recovery drive from a current windows 8.1 that works by searching 'recoverydrive' in your start menu and hitting enter.
2. For toshiba encore wt8-a-102 32gb version, after the usb is created you should copy and paste the contents of these archives:
https://mega.co.nz/#F!utYSUS5B!aOf8S33n2IGI58JMsCgHVg
The archive includes the original files from the USB Recovery Drive created by the Toshiba Encore wt8. Use google chrome to download if you don't want to install a browser extension for firefox. IE is not supported.
3. Now you have a bootable drive by toshiba encore wt8 and all you have to to is go and choose reset pc. It will take a while but your tablet will be as brand new.
						 Απάντηση με παράθεση
