Αναφέρω κάτι που διάβασα... Ποιός ξέρει....είναι μια θεωρία...
"Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power."
Απάντηση με παράθεση
