Το πρόβλημα σου φαίνεται να είναι ο waste ink counter και μιας και το error που σου δίνει με βάση τα λαμπάκια ταιριάζει με το error που αναφέρεται στο service manual που έχω για τον IP3000, ποστάρω πως γίνεται το reset του waste ink counter σε αυτόν. Ίσως δουλέψει και για σενα
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the
Destination settings procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal)
9 times Green CD-R print position correction
(vertical)
10 times or more Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
