Σελίδα 38 από 115 ΠρώτηΠρώτη ... 2836373839404888 ... ΤελευταίαΤελευταία
Εμφάνιση αποτελεσμάτων : 371 έως 380 από 1143
  1. #371
    Σπύρος
    Aug 2010
    Κέρκυρα
    ισοπροπυλική αλκοόλη και όχι οινόπνεύμα "αιθυλική αλκοόλη" ή ασετόν για ποιο φτηνά.
  2. #372
    Το avatar του χρήστη gkats
    Jun 2011
    Καισαριανή
    Ευχαριστώ πολύ Σπύρο. Συγγνώμη για τις τόσες πολλές ερωτήσεις αλλά μου αρέσει παρα πολυ το αθλημα
  3. #373
    Το avatar του χρήστη leosedf
    Συντονιστής
    Κωνσταντίνος
    Jan 2004
    Παράθεση Αρχικό μήνυμα από gkats Εμφάνιση μηνυμάτων
    ή είναι τόσο απαρέτητο το preheater?
    Ω ναι!!!
    900MHz-64GHz
  4. #374
    Χάρης
    Sep 2011
    Πτολεμαϊδα
    Από αυτά που διάβασα στο http://sheaengineering.com/Documents...for%20dist.pdf (σελ 7)
    συγκράτησα τα επόμενα όσον αφορά τα no-clean και τα water whashable fluxes. Παραθέτω:
    "Electrochemical activity of the flux’s residue determines the third tier of categorization: water washable or no-clean. A flux categorized as “water washable” is corrosive and must be fully cleaned off after soldering. Most water washable fluxes contain halides and strong organic acids Originally published in the proceedings of APEX, Los Angeles, California, January, 2007
    that are active at room temperature and do not get fully depleted during wave solder processing. If they were to remain on the assembly after soldering, they would continue to act on the metals in the circuits, ultimately causing failure. Because the fluxes are fully cleaned after soldering, options for the formulator are not as limited as they are in no-clean products, and water washable fluxes are usually the most highly active, effective ones available. The obvious drawbacks of water washable fluxes are that they do need to be washed, which adds cost to the assembly process, and that if they are not properly washed, reliability concerns will abound.
    While no-clean fluxes reduce cost by minimizing process steps, their activity levels are limited by the need for post-soldering reliability. They must be formulated to become deactivated in the wave soldering process so that their residues will be electrically acceptable. Because they are designed to fully activate and deactivate in typical soldering cycles, a cycle that is too short may not render the residues benign, and one that is too long may spend all the activators before the assembly reaches the wave. If the activators are spent during preheat, the unavailability of active materials leads to poor solder joint quality. The need to properly activate and deactivate no-clean fluxes narrows their process window when compared to water washable products. It also narrows formulation options."
    Άρα, για ένα no-clean flux, που σημαίνει ΔΕΝ χρειάζεται καθάρισμα μετά το reflow, πρέπει υποχρεωτικά να γίνει ο σωστός κύκλος ενεργοποίησης-απενεργοποίησης (σωστό profile-πιστά ακολουθούμενο) ώστε τα υπολλείματα να άπενεργοποιηθούν τελείως και να μην δημιουργήσουν πρόβληματα.
    Τώρα για το αν ένα flux είναι ή δεν είναι water washable κοιτάμε την κατηγορία του (μας ενδιαφέρει η δεύτερη στήλη και το Low, Moderate, High)
    (για αρχάριος καλά τα πάω?)
    Χάρης Θεοχαράκος
    Τεχν. Μηχ. Μηχανικός
  5. #375
    Aug 2010
    Αιγιο
    για να δουμε οταν θα ..........βουτηξεις στα βαθεια!!!!!ατιμα laptop
  6. #376
    Σπύρος
    Aug 2010
    Κέρκυρα
    Παράθεση Αρχικό μήνυμα από harristh Εμφάνιση μηνυμάτων
    Μια χαρά τα πας αλλά η θεωρία από την πράξη απέχει, ξεκίνα και την πράξη και εκεί θα αρχίσεις να μπαίνεις στο νόημα επίσης θα καταλάβεις μόνος σου ποιες διαδικασίες (solder balls, solder paste, flux, θερμοκρασίες, stencils κ.α.) είναι βασικά/χρειάζονται και με ποια μπορείς εσύ να κάνεις την δουλεία σου.
    Υ.γ.
    Τρόποι υπάρχουν πολύ αποτέλεσμα μόνο δυο (επιτυχία-αποτυχία), στην αρχή της πρακτικής ξεκινάς με το δεύτερο ή με μια μίξη των δυο.
    Μετά από αρκετές προσπάθειες θα ξεχάσεις το δεύτερο και θα επικρατεί (επί το πλείστον) το πρώτο ΕΠΙΤΥΧΊΑ!
  7. #377
    Jun 2011
    Καισαριανή
    Παιδιά έχθές αγόρασα το παρακάτω νο clean flux. http://www.ebay.co.uk/itm/ws/eBayISA...m=270820484141 θα κάνω τη δουλιτσα μου?
  8. #378
    Σπύρος
    Aug 2010
    Κέρκυρα
    Για reflow και ξεκόλλημα πρέπει να είναι ok, στο rebaling θα σε παιδέψει καλύτερα για αυτήν την δουλεία είναι το jel.
  9. #379
    Jun 2011
    Καισαριανή
    Σπύρο εχεις να μου προτείνεις καμία που είναι gel?
    Επίσης το gel flux που έχω που δεν είναι no clean να το καθαριζω με ασετον εφοσον τελειωσω το reflow και αφού είναι ζεστη ακόμα η πλακετα έτσι?
  10. #380
    Σπύρος
    Aug 2010
    Κέρκυρα
    Αυτό πρέπει να είναι οκ http://www.ebay.com/itm/Amtech-BGA-R...item3f0dadad52.
    Αν είναι αρκετα ανεβασμένη η θερμοκρασία στην pcb και ρίξεις οποιοδήποτε υγρό, το ποιο πιθανόν είναι να της πετάξεις τα μάτια έξω (πρέπει να ψιλόκρυώσει πρώτα).
